converting propane to gas
dwiles71
north wilkesboro, nc
need some help, got a 1997 gmc 7500 dump truck with a 366 (6.0) engine that is propane powered. ive drove the truck as is for a while but has become a hastle finding a place to refuel. thinking of converting to gas what parts will be needed, and is this a expensive, difficult conversion? any help will be appreciated.
dw
Not really hard to do. Basically need parts.
Carb or Fuel injection system. Not sure what the rules are as far as inspections since it is a 97. Carb would be the easiest I would think.
Carb, Fuel tank, Fuel pump, and fuel line. Possibly re curve your dizzy, and good to go. Set timing.
If you go Fuel injection, you would need a throttle body, harness from similar year, computer, fuel tank with fuel pump, and fuel lines.
