85TrailRunner
Member
- Mar 16, 2007
- Monroe
I've got an '85 4Runner that I beleieve to be overheating, I've never done any work to the cooling system so theres no telling how old some of the components are. The temperature gauge inside always reads a little under the halfway mark even after its ran for over an hour, is that normal?
Only reason I think something is wrong is because sometimes when I let it sit & run after 30 minutes or so you'll hear the coolant in the radiator boiling & even the overflow reservior will be very hot, that happened this this past summer. Yesterday I drained the coolant from the radiator(which quite possibly could be the orginal radiator) & refilled & let run for 30 minutes with the radiator cap off & every once in awhile coolant would overflow out of the radiator but then it would stop & you couldn't even see any coolant in the radiator anymore? And every few minutes a little steam would come up from the radiator? Am I not getting good coolant flow or is the thermostat sticking?
If none of this works then it could be a blown headgasket or cracked head....but think simple to complex
