- Mar 10, 2005
- Hooterville (24171)
For over 5 years, I've fought the draglink contacting the Pass.front spring (D30 NT, SOA, stock leafs, 4" drop pitman arm). Usually, it puts just a scrape on it and puts a slight bend in it. Only at places like Tellico & Windrocks when getting everything crossed up good or tires bound (usually in BFE) does the DL pretzel (3 & counting
Anyways, I've looked at it numerous times and it *appears* the PO put too much caster in (pinion pointed more towards ground than TC... steering arm on knuckle parallel/even with spring...IOW, rotated back too far). I'm getting ready to go thru the axle (balljoints, spindle bearings, LOCKER... all setting here since May), install some Waggy offset front leafs (the ducktape on my OEM leafs is starting to fray
), and new "anti-wrap" perches (OEMs are like 3" long
How do I correctly measure the caster? Some say the flat of the chunk, some the perches once the chunk is 90* to flat surface, & other "less credible sounding" methods
SCREW "eyeballing it"... that doesn't tell me anything!
This should confirm my theory and allow me to correct it with new perches. If I can gain enough between the DL & spring... Big Daddy's "ALL Beef" DL/TR set *WILL* be going in (extremely tired of this crap!) once the axle is back underneath.
TIA
TIA
