fourwheelinj1
- Apr 11, 2011
- Raleigh
Should I be able to crank my jeep with 4.2 258 with only the bellhousing installed with no transmission (T-5)? The project scrambler I just bought has a questionable motor and I want to do a compression test and get if running if it will before I waste my time installing the transmission that the previous owner removed. I pulled the plugs today on the motor to put some Marvel mystery oil in the cylinders and found that 2 of the plugs were oily. One of them was actually soaked and dripping oil which seems strange for a motor that hasn't been run in 12 years. If the rings are worn enough to allow oil to get to the plug wouldn't it allow the oil to drain back to the oil pan after 12 years?
hit the switch and let it run. Be sure and support the back of the engine with a jack and block of wood on the oil pan.
