thebrotherinlaw
- Dec 8, 2014
- WNC
The ol girl has been a good one. It was a Fral (snooty and made in Italy) and lasted 10 years. Anybody had any success with a particular brand? Thanks
Are two Keystone's equivalent to one Aprilaire? LolKeystone, off amazon or amazon basics.
Seriously.
If you just want to spend a lot more then aprilaire, but what you get vs the cost....
Stay away from Santa FE, Honeywell, alorair, horizon, and about 2 dozen other brands etc.
Thanks for the info. I'll check them out.Keystone, off amazon or amazon basics.
Seriously.
Seriously.
Will one of those little guys do 2500-3000sf of crawl space?
That's a tall order with a gas pack.All of that requires it to be actually air sealed.
Is Aprilaire really not worth it?
Gas pack combustion air should be plumbed to exterior.
It should never use crawlspace air for intake or exhaust.
Having a closed/conditioned crawlspace not air sealed, is exactly the same as running HVAC with windows open.
I'm talking about a package unit. It sits on the ground outside and has a couple of ~18-24" dia insulated flex ducts attached to it. You can cut some filler panels out of rigid insulation to close around the duct penetrations in the foundation wall, but getting it to actually be airtight is a tall order.
When you say sealed, are you including ground cover as well or just exterior air entry?
I know fully encapsulated is ideal and best for encapsulated control.
Things have come a long way in 10 years. Encapsulated used to mean heavy lining that covered the floor and the insulation on the block exterior walls. Everyone swore you had to have that heavy vapor barrier on the ground and every joint sealed with tape. I have been properly schooled. Thanks man!I mean perimeter walls air sealed.
Ground vapor barrier actually doesn’t contribute much as far as moisture load. Without one yes the Dehu runs more as you are trying to dry the ground where the air meets it,
But even if there is puddled water, there is very little heat input to cause the phase change from liquid to vapor where it could then be absorbed by the wood and cause harm. Especially given the typical ground temperature.
Yes, vapor barrier vs no makes a small difference, but that difference is far less important than perimeter wall sealing.
The type of vapor barrier and specific of type/thickness poly generally make zero difference to the moisture load.
Ideally, what I shoot for, is no debris under vapor barrier to cause holes in it,
All soil covered, plastic extending up and onto curtain wall. 3-4” minimum gap from wood sill for termite inspection, and 12” above exterior grade.
The plastic on the wall makes more of a difference in the winter, when the north side wall temp can drop below the crawlspace dew point.
Overlap of plastic pieces 12” minimum, pieces pulled taught and fastened to soil every 12-16” at the overlap.
Not important to wrap interior or exterior piers as the moisture load from wicking up a CMU block isn’t enough to warrant the extra cost.
Ie: meet/exceed code for vapor barrier, and don’t cover up wires/pipes etc unless they are below grade.
Plastic pieces are installed opposite of shingles, so if any water enters for any reason, it runs downhill and under the next overlapped piece.
12” overlap and fastened is same as taped/sealed/glued overlap in terms of moisture load.
This is a terrible wall penetration to leave unsealed.
Agreed. My original point was only that it's difficult to do. Sealing vents just takes a sheet of foil faced and a can of great stuff. Sealing 2*5ft hole against a pair of flex ducts takes the better part of a roll of tape, and you're lucky if it's still in place a year later.
I bought a tosot and have been really impressed with it. It does have built in pump as well
Looks very similar to keystone/amazon basics one. Should be pretty good and last you a while for the cost.
Does it have a copper or aluminum coil behind the dust screen/filter.
My only complaint with that one is the top air outlet. I try to find ones that have rear/side air outlet so in shorter crawlspaces it isn’t dumping the air straight up towards the floor/insulation. But that’s me splitting hairs for my typical use haha.
