RatLabGuy
- May 18, 2005
- Churchville, MD
So, we just bought a 'new" house (ok 42 y/o) thurs.
Before moving in, wnated to do some minor things, one being add cieling fans/lights. Noen of teh rooms have overhead lights, although they do have switches.
so I figure... ok I'll find the outlet(s) tied to the switch, and go from there. Well, turns out... all outlets rae hot, switch seems to do nothing.
Huh...
Pull switch out - only 2 wires coming in. OK, I have an idea how this works, wires are both used as "hot" and in the box white = tied to hot.
Well, kind of.
Whole room is actually wired as follows.
Line comes up from the breaker to first socket. 2 conductor.
black tied to bottom post hot, white on bottom neutral. A line going out is... 3 conductors... whit tied to socket top neutral, bllack tied to otehr black line.. and red tied to top hot. So not the 3 conductor has 2 hots & 1 neutral. This passes to 3 other sockets, all all same - 3 coming in, 3 out, red on top, black on bottom. Mind you on every one the top and bottom legs are stil ltied together. Last one goes to the switch - a red and black line goes to the switch.
so needless to say, te hswitch is useless - it simply connects 2 already hot lines together.
WTF?? How could this happen? The seller said he'd had several sockets replaced recently, and in the inspection, inspector found a handful not preoperly grounded... seller allegedly had an electrician fix it all.
The only thing I could think is that all the TOP outlets should be switched, and bottom always hot. I've seen ths idone before by breaking the tabs and seperating the components. However having the tabs still in place makes this impossible.
Is it really possible that this was the original scheme, and someone could be so lame as to go and replace all of the sockets (who knows why), and not realize that they forgot to do this when they flipped on the switch to test it?
Or am I misisng something important?
I lost a whole freakin' evening trying to figure this out.
Huh...
Well, kind of.
