Creepers and PSI
shelby27604
Efland NC
Been driving my Ram 2500 around a lot lately, and it has reminded me of a couple of long term questions I had from the last time I ran a 3/4t with the NV4500.
1. Do you use the creeper gear w(1st gear)d around without a load, I have been told not using the creeper is a sure fire way to premature clutch failure.
2. Do you air up and down your E-rated tires based off of the load you are towing/carrying? When I brought the truck home, the PO had the tires aired up to 70psi, unloaded the ride and handling was awful, I pulled them all down to 40psi for the ride home and everything was significantly better.
I usually use 2nd in my CUCV.
I run 55 all the way around my 2500HD. If I tow very far, I'll air the rears up some more.
I always take off in 2nd unless I'm loaded. Had truck for 11 years and no clutch issues since I replaced the factory craptastic dual mass setup at 16k miles. Has 108k now and no signs of wear.
I run 50-55 psi all the way around and if I'm towing heavy I'll bump the rears up.
