I am looking for the best factory replacement fuel filter for my 03 5.9ho I'll also be buying this for some extra protection. http://www.cumminscatfuelfilter.com/index.html
They are cheaper at Cummins Atlantic.Shawn I can't find that kit just this. http://www.genosgarage.com/FLEETGUA...R-03-07-59L/productinfo/FS19856/#.U530RO29LCQ
Might also look into a Baldwin pf7977. According to most, it's the best drop in filter available.
I was about to say...a year or so ago I could have hurt that price 40+%...and made a profit.
Good to know, I'll give them a call for next filter change. I want to stick with Fleetguards.
Well that would've been good to know a year or so ago
Any additional filtration/water separation will help prevent injector failure
If you add a tuner or other modifications to utilize the injectors you'll need to keep an eye out for fuel delivery issues. The factory pump is sufficient and can deliver the minimum volume spec no problem but likely won't support higher power numbers.This truck has a fresh motor so I want to protect it. It also has new 60hp injectors Thanks Shawn
