- Mar 17, 2005
- N. N. Raleigh, NC
Cummins.... How far forward should i place #6 plate?
and WHY !!!!
I am shooting for ~250 hp
Specs..
1995 5.9 160hp (stock) p7100
with Head Studs, he351, 4" exhaust, muffler-ish,
stock injectors,
bumped to 14.5 tdc
3K GSK
Just the RV
I waiting on a spring to go in the AFS (sp)
...basically it take your control part of the throttle it bumps it out like 20%
because you/i grind a little bit off the part mechanically slides back/forth
AND the washer you grind it down eliminating ~2mm on the boost measuring thing]
so you get like....
[12345678]
[1234567890].
And it a longer spring and bit softer spring (per vendor).
I bench tested it and i can see 0 to tiny bit over 20 lbs of boost. Good ? / Bad ?
so....
How far should i place the #6 plate forward ?
1/2 , 3/4 all the way ?
Star Wheel ?
and WHY !!!!
Specs..
stock injectors,
bumped to 14.5 tdc
3K GSK
Just the RV
so you get like....
[12345678]
[1234567890].
so....
Star Wheel ?
