YotaOFFroad27
- Nov 20, 2009
- Oxford
I need info from people who know, on OBD II engine swaps. What needs to happen to make it legit. ECM will match engine and engine harness. The engine harness will splice into the dash harness of the swap vehicle. I would plan for the ECM to function properly, display codes, and sore codes in a factory manner. My goal is to be able to plug a scan tool into the OBDII port and everything funtion correctly.
My potential swap is a 2004 2uz-fe 4.7L Tundra engine into a 1999 Toyota Tacoma. I understand the practicality of the swap, and most of what is involved in the swap. My main concerns are what sort of red tape is out there?
When an inspection is being performed on an OBDII vehicle, what info is put into the computer? Will the inspecting computer be able to tell, or care that the ECM it is looking at does not match the vehicle it is plugged into?
