I've combined sets (added a leaf or 2 or 3) before and can give a few pointers if that's the direction you want to go.
1. Never have a longer leaf below a shorter leaf (not even slightly). Causes for some funky spring bending. The one above the shorter leaf naturally wants to bend down and touch the longer leaf below the shorter one.
2. Never cut a top spring and leave any of the eye thinking it will line up with another eye. It don't! Ever!!!
3. Don't bother trying to take the center pin bolts out for they will be too short to repack the spring anyways. Just cut them and replace with an ordinary bolt sticking from bottom up so you can get wrenches on it to torque it. Use one that is plenty PLENTY long enough with PLENTY of thread. Use good clamps to pack the springs together and tighten the bolt and nut. Then grind the bolt head round enough for it to slide into the mounting hole. LEAVE EXCESS THREAD ON CENTER BOLT UNTIL YOU ARE SATISFIED!
4 It's very difficult in determining lift you gain for the spring rate system as a whole changes when they mesh together. I do one side at a time and add 1 spring at a time, reinstall, drive all funcky with one wheel jacked up for it to settle, then check height for desired lift.
5. They will settle even more over time. I added 2 leaves to my truck (for more load capacity) and it jacked it up ridiculous. One didn't change enough for me. So I got a couple tons of gravel and let it sit for like 2 weeks. It put it right where I wanted it.
6. Either tack weld the nut to the threads or drive a punch into the thread close to the nut for it to remain permanent after you're satisfied with lift and cut the extra thread off.
7. Stick with the stock pilot hole size. The more you drill it out, the more the spring leaf becomes the weak point. Never saw a bolt snap but seen a MANY springs crack at the bolt.
8. And of course the least amount of lift block the less tendencies for wheel hop and less tendencies for the springs to "S" shape on you due to axle torque. Spring lift is 10x better than block lift but also results in stiffer ride. Try to keep the block lift at a minimum. I'm a tad rough on my trucks so I prefer stiffer ride over weaker springs but also depends on the use of the truck.
9. Aluminum lift blocks , wedge blocks , spacers of any kind in a metal spring system are a complete joke. Metal beats aluminum like rock beats scissors...
Hope that helps!
