cutting jk flares
briang
Member
Has anyone around the Salisbury area cut their flares I'm wanting to cut mine but don't know how to any help would be great thanks
Check on you-tube for some vids. They'll give you an idea of the process.
I used a jig saw and it was a quick and easy. You can use a sawzall, but I found the jigsaw easier to control. A small cut-off wheel will also work, and makes cleaning up the flare support in front easy. I used a large flat file to finish the edges and then topped them off with door edge trim molding.
I removed the rear fender liners and discarded them and just trimmed the front liner.
I can get close up pics if that would help??
Here ya go
I would help you for sure, no charge. I'm south of GSO, so the logistics part would be the problem.
You can do it, trust me. The first cut is the hardest, after that it gets easier
