Cutting tires
heat up a wood chzail (SP) and cut them off. they come right off. clean it up with a grinder.
Another good way to cut tires is to sharpen a long sawsawl blade. Grind off all of the teeth and make it sharp as a knife and it will cut the lugs off in no time! :beer: Like butter!!
thanks for all the hints think i will try them all, Ive seen some profesional cut boggers by Jimmy Dean they are awesome scooped and lightend.
I spoke with some monster truck guys up in lima ohio and they said they would take a ginsu knife you buy off tv and cut it to fit a sawzall. One person would cut while the other would use some pliers to peel the rubber back so it wouldnt melt back to it. Then they would use a flap wheel on a grinder to smooth it out and give some scoops.
i want to see a monster truck w/ boggers
