d 44 seals
1badrig
Member
Abingdon
ya im leaking on my front d44 is there an inner seal and an outter seal or wat exactly is there ne answers will help and let me know the easiest way to replace them thanks
Inner seals. Have to pull the axles and remove the carrier to change.
If we can help you out just let us know and we will be happy to.
There are 2 or 3 possible seals and we have them all in stock.
You are a bit away but if you feel like making the drive we will be happy to hook you up.
where is it leaking? theres also a pinion seal and (of course) diff cover gasket. if its a ford TTB then replacing the axle seals is not quite as easy.
