D-shaft u-joint rubbing pinion nut???
my bro's 9" did it on his race car w/ this one gear set, the pinion busted the joint by pinching it when flexed.. We just hit it with a grinder and painted it to spot any new contact.. Was fine after that..
This is the same issue I have been having on my rig. My front wraps so bad that the ujoint ubolts in the yoke are almost worn in two. I have broken the tabs out of three yokes this year, so.....I just installed a strap from the nose of the pinion to a fixed upper support. Flexed it out and did some measuring and came up with a length I hope will limit my pinion wrap and not hurt my flex. Will be testing at the SFWDA convention next weekend.
