GubNi
8 lug disc brakes?
- Mar 20, 2005
- Jonesborough, TN
I just rebuilt the D300 with 4:1 kit. The front axle shifts fine, but the rear is almost impossible. Any ideals?
Did you shim the springs? New detent balls? Overtightened pivot bolts?
Has the shift rail been properly clearanced for the gear?
I remember the rail looking so shiney and pretty. It wasn't warped. Someone told me I might have the shift forks reversed. Is that possible? Would that cause the problem?
I just put a D300 back together last week and it's still sitting on my work bench . But, I can't positively remember if it would be possible to put the forks in wrong or not. The way I remember them being drilled for the setscrews it just might be though.
Pull the bottom cover off and have a look.
