D300 fluid ?
fattypackard
VA Beach
i need to put fresh fluid in the d300 in my 83 CJ7
i know most cases take ATF...but wasnt sure about an older d300
should this take ATF also or gear oil?
thanks for the help
^ perfect, thanks for the info!
also, what about 75 90 synthetic?.
That will be fine but if it's a trail only rig you really shouldn't bother with expensive gear oil. I used to run it but if you don't sustain highway speeds it's not worth it. I seem to leak or break enough that expensive gear oil didn't make sense for me. I'd say that's fairly common for a dedicated trail rig.
