PuNacMC
- Jun 14, 2005
- Winston-Salem
Ok, I have a d35c that broke on me. It had a trac-lok and ABS installed. I was able to get my hands on an old d35c with a trac-lok. Only thing is the axle is not set up for ABS and it is rusted drum to drum. I want to replace the carrier from the d35c that isn't busted and put it into my axle that is under the jeep now. This is my first time messing with the carriers and I have no experience changing them out. Will these two carriers switch out? They both have the same gears, and I'm assuming the same spline count. If they will swap out, can anyone point me to a good writeup on how to replace the carrier? Thanks for your help - Mike
