d44
matt lowe
McDowell
I have a d44 from a 00 dodge 1/2 ton . My question is will a stearing knuckle from a Chevy d44 fit the dodge housing. I am trying to do away with the dodge wheel bearing and have a locking hub.
I was going to do this when I had a dodge. The inner and outer knuckles on the dodges and jeeps are the same, but different then the older style axles... It is possible to do, but you will need from the inner knuckles (C) out including the stub shaft from the older axle... sorta like this:
http://www.pirate4x4.com/tech/billavista/Hybrid_Axle/HybridAxle.htm
