89wrangler
Not a new member
- Oct 22, 2005
- Bostic,NC
You all have probably figured this by now, but new to the D60 scene. Working on a high steer set up. Few questions,
1) it appears that when you install the high steer arms, you do not use the original caps and springs. Is this correct?
2) can you just buy the seals and plastic cup for the king pins or do you have to purchase the whole rebuild kit and use what you need?
3) On the high steer arms, is there an advantage/disadvantage to having the drag link attached to the high steer arm (two holes on passenger arm) vs having one hole on passenger side and it attached to the tie rod?
