D60 Rear Disc Brake Bracket (Ford)!
Dan Fredrickson
Sacramento
Here you are, an easy bolt on bracket for the Ford D60 Rear axles! This one also uses the GM Caliper ('73-87 3/4 Ton 4x4 Front) because it is 1/2 the cost of the Ford and way less expensive to put together than the wedge system. The rotor is a '75 Chevy 3/4 4x4 Ton Front rotor. These were a long time coming but way worth the wait! These come with the required hardware. All of our brake brackets are sold in pairs.
awww.ruffstuffspecialties.com_gallery_albums_userpics_10001_normal_ford_20D60_20disc_20bracket1.jpg
These are only for the Ford D60, if someone tells you they are the same hang up the phone, they, the GM & the Dodge are all different!
AS always $50 a pair! And don't forget the discount!
