78mudbugg
- Oct 8, 2006
- granville co.
Caster...needs...to...be...negative...
"King pin axis" should be tipped back at the top shouldn't it? (Thas positive caster)
so i should turn the c down? does this sound crazy to anybody else?does anyone know what i can do about the coil spring bottom plate not being level?
thx for all the input, superlift has the 9 inch lift with 7 degree c bushing, so i figured being that i have the same coils minus the wedges cause it is a d60 with weldon brackets,that that would be what castor i neede to go with?I am thinking right?Also about the ride height, does that need to be with weight?Like the motor and etc.
