I've heard plenty of trash talked about these axles. I was wondering if they are as "weak" as people say they are.. Would they be strong enough to handle a set of 34 10.50s? I would be welding the rear diff also and adding a lockrite to the frount.
The 30 will be good, although I would carry spare shafts. If you have a problem it will most likely be a ujoint or an outer shaft. I would be leery of the 35, especially if you wheel it much. They are prone to break shafts and differentials, especially when locked.1stgenxxx said:I've heard plenty of trash talked about these axles. I was wondering if they are as "weak" as people say they are.. Would they be strong enough to handle a set of 34 10.50s? I would be welding the rear diff also and adding a lockrite to the frount.
