- Jun 19, 2007
- high point
Just got a 99 Tj with the 30 still upfront. The problem is when you back up the wheels put in at the top then when you pull back forward the straighten back up. I've replaced the tie rod ends, the unit bearings, and the poly bushings in the lower links. The only thing we've found that seems out of place is the lower link adjuster bolts were replaced with reg bolts and rounded out the slide adjuster on the axle. Has anyone else seen this or have just got something that odd. I've had it aligned twice and it was dead on until I backed up and the shop guys just said that's odd and pulled it around!
