dana 30 question
HighrideCherokee94
King NC
Okay I've got a 94 zj with a dana 30 front axle with cv axles and there shot. I also have a dana 30 with u-joints but some teeth are broke off one of the gears or id just swap them out. But my question is can i swap just the axle shafts Id basically be swithing from cv to u-joint any pros and cons to it and is it possiable?
they will swap out & u-joints are stronger the your cv
lots of pros to u joints over cvs.
#1 they dont break as ez! get 95 or newer xj hp dana 30 you get the biggest u joints they put in stock.
All axles are the same size xj/zj. axles should swap out with out any problems.
another upgrade is wj kuckles on the hp dana 30. then the axle should hold a set of 35s with upgraded axles.
My research has taken my painful days.... i lifted the truck useing and explorer spring set rides nice and all gain lots of play room but maxed out my stock shocks so im hunting down a new set today.
