dana 300 dub
I have a 203 gear box I'll sell you if you want to build a doubler..
I doubt it. I'm sure it's possible but the time, effort, and $$$ to do it wouldn't be worth it. There are better and easier options out there.
It has a cast case. You would likely have to divorce mount the second one.
ok i have the aw4 tranny what i have a 300 i might trade for the right stuff to make a dub now i have pass drop is that doable
You *could* do the following if your front axle is passenger side drop:
flip the front 300 so the front output is on the driver's side. Then run a custom spud shaft between it and another divorce mounted 300 with the output on the passenger side.
That's a lot of work to have already weak outputs trying to handle 2.62 times the torque.
Waste of time. Just install a set of 4:1 gears and upgrade the output shafts while you have it apart.
naw the 4.1 is to much for me right now thank you jody thats what i was thinking
