petermobiling
- Sep 30, 2006
- jacksonville
just wanting to see if anyone could offer some direction on removing the output gear set from a dana 300 t-case. I decided to tackle putting bearings in it without any literature. I've done alright sofar, just can't get the rear shaft out. I got the housing and rear bearing out, but there is still one gear and the shaft inside the case with the sliding clutch collars on it. also when I go back with it, is there any timing marks for the gears, I didn't see any, and what is a good way to get the needle bearings to stay in the center shaft, so I can put the shaft through the case. Thanks for any help in this matter.
