Dana 300?
Bridgeman
Anson County
Alright fellas I am swapping the t-case into my YJ with chevy 1 tons. I installed the Advance Adapters twin stick kit and now the shifter bracket and shifters are hitting the floorboard. I know I will need to cut the floor but I would like to see some pics of what others have done that might have had the same issue. Basically looking for ideas to box the floor back in.
Thanks
Sorry I can't help. I put a 203 infront of my 300 on my YJ.
My advise is to cut a hole way too big and then patch over it.
Cut a nice big hole so you have access if you ever have to pull it, to the linkage and such. Then once in, measure a larger plate to go over it. cut the shifter hole so you have full movement of shifters and put the boot on.
I get the concept of the issue. I was just looking for some different ideas to box it in to give it a more custom look.
