Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
I had an idea, since Dana 35's are so worthless you can pretty much get em for free if not extremly close to it. So I started thinking, what exactly are the weak points on a dana 35 looked it up and found that its the spider gears and the shafts which are held in place by C clips which causes the infamous tire "walk" when a shaft breaks. Since Dana 35's are so frikin cheap and easy to find I was thinking about doing this:
On a trail only rig that's just budget lifted for now (my bro's xj) until he can afford to build his larger axle combo he has, why couldn't I just pop the diff cap and literally weld the entire spidergear, c clip, axle shaft ends, carrier into one big frikin ball of metal?
This would not only give you a locker, but would also fix the problem of the weak spider gears since its pretty much one huge hunk of metal after that. You would also never have to worry about the c clip failing.
Granted the shafts are still weak but like I said b4 dana 35's are as easy to find as unwanted used clothing, not only that but we already have and extra set of axles anyway. And swapping in a rear leaf sprung dana 35 is easy as crap. So if you blow up a shaft, big whoop toss another one under it ya know?
Honestly since Dana 35's are not really heavy and since we have tha backseat pulled we could carry the spare axle when we wheel and if one breaks we unbolt ssome bolts, bleed some brakes and viola keepon goin, easy trail fix.
Feel free to give me some feedback on what im not thinking about, etc. etc.
