frontiermudder04 Member Joined Jun 14, 2010 Location Landis, NC Jul 7, 2010 #1 i am getting a dana 44 out of an 84 jeep j10. im going to run a 5.38 gear. the gear that is in it now is a 3.31. will i be able to run the 5.38?
sweetk30 New Member Joined May 2, 2010 Location horseheads,ny not nyc Jul 7, 2010 #2 you will need a diffrent carrier . you need one from a 3.9? -up . thats the split.
frontiermudder04 Member Joined Jun 14, 2010 Location Landis, NC Jul 7, 2010 #3 alrighty. preciate it. do i have to get new spider gears and pinion shaft?
sweetk30 New Member Joined May 2, 2010 Location horseheads,ny not nyc Jul 7, 2010 #4 na just carrier is diffrent. thicker or thinner for correct spacing of the ring gear to center of were it needs to be. thats all.
Metto Well-Known Member Joined Mar 20, 2005 Location Cornelius, NC Jul 7, 2010 #5 actually you dont need a carrier......you just need a thick gear
sweetk30 New Member Joined May 2, 2010 Location horseheads,ny not nyc Jul 8, 2010 #6 i didnt think thay did std rotation for dana in thick.
amcjeepman Si Vis Pacem, Para Bellum Moderator Joined Mar 18, 2005 Location Reidsville, North Carolina Jul 8, 2010 #7 TJ "Rubicon" gears are thick gears for the Dana 44. I think they can be had in 5.38's.
