Dana 44 Info/Help
Duranged98
Oak Ridge
I have a 76 dana 44 which is a low pinion and I need a hp dana 44. Question is can the parts from a 76 lp work in a 79 hp housing (shafts, brakes,hubs, etc.)?
depending on ford/chevy/jeep/dodge the hubs and brakes may interchange, or if you want to just swap knuckles out then anythign should interchange, but the shafts may be different lengths...if your dealing wth HP its ford but which LP axle are you workin with?
