Dana 44 lug studs
GrnRanger
Raleigh
I got new hubs, rotors, lug studs, etc for my SAS im working on. tonight i was tryin to put the lug studs on the hub/rotor and could not get them to seat through the rotor and into the hub. so since they are not seating completely, theres a gap. i tried a mini sledge and an air driver/hammer but neither seemed to work. i also tried to torque on a lug nut using an impact... still nothing.
do these have to be pressed in? :confused: got two pics below to help explain. thanks
You have the dustshield in the wrong place.They go over the studs on the knuckle not behind the hub.A hammer and a punch usually does the job.
if you mean the disc brake dustshield, yes, it goes on the knuckle studs between the caliper bracket and spindle. but thats not where i have the problem. i'm pretty sure i have it put together correctly, but there is still a gap between the flattened backs of the lug studs (pic 2) and the inside of the rotor face. meaning, i don't think they are fully seated. heres a pic of a TTB dana 44, different axle but same idea. you can see the studs fit through the rotor and into the hub:
hope that helps
Don't pull it together with a lug-nut. If it does close the gap, chances are it will f-up the threads and you'll just have to start over. It is probably best that they are pressed in.
