Hetooknails4me
- Nov 4, 2010
- Reidsville
Pressed new ball joints on my 1985 k20 today. Now i have run into a problem. The locking hub mechanism will not fit back into the hub. Is there a trick to this because I have messed with it for a little over an hour . Also, the two nuts the hold the hub to the axle, does the nut with the pin go on first or last also. There is a washer with holes that goes between the two. I am just wanting to make sure i put everything back the way it is supposed to. Thanks.
