Dana 44 spider gear removal
bowtieman55
Edenton, NC
I've pulled the axles on a C-Clip 10 bolt before, but never a Dana 44. What has to be done on a 44 to remove the spider gears? The patient is a offset 44 in a '77 Wagoneer.
edit*
I'm referring to a REAR 44...also, are the carriers for Dana 44s the same front and rear
Carriers are the same, based on the ring and pinion ratio.
You have to remove the set pin and then drive out the center pin. the spiders will fall out them.
thanks yall...just trying to make sure I was correct before I passed on any information.
