4wheelsupply
- Jul 11, 2006
- Richlands VA
Just finished this new arm today. It is a newer version of my standard arms with tie in kit. They are a combination of my thick milled arms and my tie in arms. so now you can have the best of both worlds. 3/4 Hardware for knuckle tie in kit is included. As well as a set of studs for the arms.
$200 to your door.
What you will get:
1 pair of arms (1 pass 1 driver)
2 Pcs of 3/4-16 Grade B7 all thread
2 pcs of 3/4" ID DOM
4 Nylock Nuts
1 set of (8) studs and nuts
1 Springless conversion ( set screw, jam nut, and custom thick washer)
YOU CAN ORDER DIRECT FROM MY WEBSITE HERE! Four Wheel Supply - Dana 60 thick Milled High Steer arms with Knuckle tie in kit
These arms are also avail in a double ended arm.
$200 to your door.
What you will get:
4 Nylock Nuts
