dana dual wheel
nathan79
waynesville
im trading for a dual wheeled dana rear end not sure on 60 or 70 yet but wat do you have to do to make it single wheel this maybe as simple as just putting one wheel on haha just curious before i do trade
No, more to it than that. It depends on which hubs you use on what housing width. The Dana DRW axles have a wider than SRW width (wheel mounting surface to wheel mounting surface).
What width are you attempting to end up with?
im just doing single wheel an 35x12.50 tires im getting it for the gears mine is 355 this one is 410
the width of the DRW axle housing is likely wider than a SRW axle and very likely it won't match the front.
You could add spacers to the front to match but you start sacrificing driveability and affecting your scrub angle, etc.
measure the width of the axle from wheel mount surface to wheel mount surface and be sure the rear is similar.
Gears from a D60 will work for a D60 as long as its not a HP. Same with a D70
