dana/warn trouble
brios
Icard,NC
ok i got a dana 27 in the front of my cj5 and ive removed the warn lockout (6 bolts) then the 1in spacer between the drums hub and the lockout that holds the roller bearings in place but the cage for the bearings will not come off anyone who can make any since of my giberish help? :confused: or anyone with a danna 27 with 3.73 gears who wants to sell it :rolleyes:
no im talking about if you remove the hub then the bearing race and the rollers out of the cage and then try to remove the cage to get to a positon so u can remove the hub / drum
Sounds like you have not removed the 2 spindle nuts that holds the bearing in and hub on. If push comes to shove, I have a D27 with 3.73 for sale.
in the link above is a pic of what im trying to remove so i can get to the two nuts so i can remove the hub
