buddyantunez1
- Feb 26, 2013
- Raleigh, NC
Hey all, I am about to the point of driving my XJ Cherokee off a cliff. I'm pulling all my hair out trying to figure out what could be causing my death wobble and other issues with the front end. Some days it will death wobble at 35-40 like it's going to fall apart, and others it has no wobble at all.
Here's a run down of what I have in the front end.
-98' XJ, 4.0, Auto, 132k.
-HP Dana 30 with 4.88's and a lockrite locker.
-Riddler diff cover
-6.5" lift on teraflex adjustable control arms, and trac bar. (Long arms in the garage waiting to go on.)
-35x12.50x15 KM2's on 15x8 steel wheels.
-1.25" hubcentric wheel spacers.
Parts that have been replaced in the last 800 miles/2 months or less.
-Spicer ball joints
-Spicer U-Joints on the front axles
-Rebuilt front driveshaft
-Advance auto brake pads
-Pinion seal and bearings
-Axle seals and bearings.
-Steering replaced with another used setup. Tie rod ends all feel good.
Now onto other issues that go along with the death wobble. The front locker seems to be locked up at all times in the past week. It leaves tire marks when turning in and out of the driveway and I can hear them barking when turning tight.
The front wheels look to have camber in them. Which I know isn't adjustable. And it's enough camber that even a non-mechanically inclined person can notice it. Pulled the whole front end apart and nothing looks bent, wore out or has play in it. Put it all back together and the wheels line up perfectly. Drove it around the block and they can still be strait or one of both of the wheels can be cambered again. It's like the camber comes and goes. Hubs and ball joints are all tight.
My only thouts on what else could be wrong is the locker springs and pin can be wore and causing the axle tubes to bind and death wobble and/or camber the wheels. Or one of the axles are bent causing everything to bind up.
Can anyone think of anything else I can check before breaking down and buying new axles and a locker rebuild? I'm about tired of buying rtv and gear fluid from pulling everything apart multiple times. Only other thing I can think of is measuring the axle housing to make sure it's level, which it appears to be. I greatly appreciate any help or advice in advance.
-Kyle
Pics for reference:
-Riddler diff cover
-Spicer ball joints
-Kyle
Pics for reference:
