RatLabGuy
- May 18, 2005
- Churchville, MD
I need to do some minor grinding in a hard-to-reach place - mostly removing weld spatter and removing a small bit of weldment that will be in the way of another piece fitting.
The usual 4" grinder flap disc won't fit.
I do have a Dremel tool (well another brand but identical)
Is there an attachment that is good for grinding metal, other than the typical small cutoff wheel? That angle is off by 90 degrees.
What would be great is something like the sanding "drums" used on Dremels but sufficient for steel.
... yes, it would help if I weren't a hack welder, but hey, that's easier said that done
