BallzF250
- Feb 24, 2010
- Wilmington
I know the trick about raising the rear end, marking the tire and drive shaft, and spinning the tire 10 times while counting the drive shaft, etc etc.
Do this method work on the front drive shaft as well?
I've got an '83 Bronco that has different gear ratios in the front and rear differentials. I guess the previous owner didn't use the 4WD at all and changed the rear ratio to get better gas mileage. I'm trying to figure out what the front is, so I can match the rear to it.
The front is a Dana 44 IFS (the twin traction beam) and the rear is a 9".
Thanks in advance!
Thanks in advance!
