RenegadeT no shirt,no shoes,no dice Moderator Joined Mar 24, 2005 Location Stokesdale-Greensboro Jul 21, 2012 #1 is there any reason not to use DexMerc in the PS system (stock 4.0L XJ)? One less fluid to carry, plus I think DexMerc is cheaper than PS fluid.
jeepinmatt #1 WEBWHEELER Moderator Joined Mar 24, 2005 Location Stanley, NC Jul 21, 2012 #2 There is a reason. Its not called "power steering fluid". I've used it many times before with no ill effects, and wouldn't hesitate to do it again.
Chris_M Well-Known Member Joined Apr 12, 2005 Location Durham NC Jul 21, 2012 #3 FWIW, hmmwv's use dex it in their powersteering system, and it's just a standard GM pump and gearbox. I use it in my jeep, and have never had any issues with it.
transman731 get your shift together Joined Mar 13, 2010 Location Raleigh, NC Jul 21, 2012 #4 i use it in 95% of the cars i work on for p/s fluid, with the exception of german cars and hondas.
Black Bear Well-Known Member Moderator Joined Mar 21, 2005 Location Raleigh, NC Jul 21, 2012 #5 I run it in my toyota, which has the same pump as an xj. DO IT!
71chevytruckguy Well-Known Member Joined Nov 8, 2008 Location Kernersville, nc Jul 23, 2012 #6 Its what I run in all my stuff. Have also noticed it has some stop-leak qualities to it, imo.
Caver Dave Just holdin' it down here in BFV Moderator Joined Mar 10, 2005 Location Hooterville (24171) Jul 23, 2012 #7 Ditto... for years!
1983Bronco Well-Known Member Joined Apr 10, 2005 Location On your mom in Winston Salem NC Jul 23, 2012 #8 it will explode if you hit the rear of a toyota!
6BangBronk Well-Known Member Joined Jul 15, 2005 Location Durham Jul 23, 2012 #9 Some earlier Ford systems request it... Calls for it on the actual dip-stick. I've had better luck running it without leaks.
