REDLYNER
Mall Crawling Race Rig
- Oct 31, 2008
- Mountain Island
Trying to track down my vibrations and whirring noise in my TJ. Any suggestions?
Issue: Loud "whirring" noise upon acceleration, almost sounds like gears. Vibrations through entire cab. Noise and vibes happen 90% under acceleration, almost completely go away under cruising. But not entirely. Vibes and noise increase as speed increases, but strongly reduce once desired speed is reached (only reoccurring as gas is applied to maintain speed).
Checked so far:
*Unhooked front driveshaft, still same symptoms.
*New Atlas has roughly 300 miles on it, full of fluid and no leaks.
*Rebalanced rear driveshaft with new cardon joint and ujoints.
*Pinion angles look good.
Leads me to believe either bad pinion bearing or bad pinion yoke. Just curious how to diagnose or isolate to confirm. Any suggestions? What pictures or video could I post up to help better describe?
Thanks!
Checked so far:
Thanks!
