Keith1138
- Nov 18, 2015
- Harrisburg NC
My jeep Cherokee 4.0 was leaking from the oil pressure sending unit adapter the piece that the unit threads into which in turns goes into the block. I carefully undid the sending unit because I knew that they are fragile but I did hit it with wrench when it slipped it turned the plastic piece on it about an 8th of a turn. After pulling the adapter and unit off I then cleaned the area then applied rtv black on the threads and carefully reinstalled everything making sure I didn't smear rtv into any of the ports.
Now I will get low oil pressure, none at all, or normal all with in a 2 minute period. Engine had great oil pressure this morning.
Could that have broken the sensor?
Should I have used rtv with copper in it so the sensor could ground?
I do not have much experience with sensors so any help is appreciated.
