Diff Covers $110 TYD lower 48
Greatlakeoffroad
Steel Central
Well, in the 6 years we have been producing these there have been alot of changes and updates to our line. I thought that we should try and state it in a simple format so everyone could see what we have to offer. Below are a couple of pics that shows why we are set apart from the other guys, options only here at GLO.
attachment.php
attachment.php
attachment.php
So here are our specs................ all for $100 per cover
- Bolt ring 1/2" thick (we engineer strength where it is needed )
- 1 pc machined fill plug, placed for added oil capacity
- 1/4" thick one piece cnc formed cover (why not thicker? read the warranty "Lifetime" see below)
Only at Glo x-tra cost options......................
- Counterbored mount holes (yes all of them, for a clean quality look)
- Integrated drain (ever cross deep water? Drain it out replace fluid and go we machine this in the bolt ring)
- 1/2" mid plating severe abuse, makes a nice hydro steer mounting point also
- And everything in between (which includes top tabs for 4 link / axle truss mounts and so on)
-Realize we designed these and they are not some cheap knock off and we cater to the custom builder
-Let us know what you need.
Models available
Dana 80
Dana 70
Dana 60
Dana 50
Dana 44
14 bolt 10.5" R&P
14 bolt 11.5 R&P
Ford Sterling
Ford 8.8
Dana 30 and 35 to be here by Months end
Warranty ( No B.S. Fine Print )
You break it under use we replace it and add you to the hall of fame as it has never been done in the last 5 years. Our design has been engineered for strength. We weld these the proper way utilizing machined fixtures. You ask why we don't machine them? Because we never had a problem w/ leaking unlike the other guys who need to machine them as fixtures are an after thought.
If you haven't seen our work you can check us out on www.greatlakeoffroad.com We had these covers in the last issue of JP magazine and they consider these "Bulletproof". No not the 1/4" cover the one w/ the additional plating making it a whopping 3/4" thick! Thats double our closest knock off.
Thanks Shawn
Call 260-387-1428 for quick order processing.
