Short answer is no, you can't do it. The CR has three different pistons (03-04, 04.5-05 and 06-07) 04 and 04.5 were different due to the 3rd injection event added in 04.5. This event was necessary to create higher EGTs to keep the added Cat cleaned out. If you buy a used motor you need to be sure 100% which one you have. The 8th digit of the VIN on your truck will be either a 6 if it is an 04 and a C if it is an 04.5. 04.5 also has a bigger turbo. The 03/04 has an HE341 and 04.5-07 has the HE 351. These trucks are getting old enough now that you cannot tell by looking at things like turbo. I have sold many used HE351s to people that were putting them on their 03/04 trucks. None of the CR pistons will have the same bowl design as a 24 valve. The timing gears are straight cut in a CR, where they are helical (angle) cut in 24 valve and older, so your CP3 would not work with a 24 valve cam gear. The timing gear case, from what I have read (I cannot personally attest to this), has a different bolt pattern on a CR, so you cannot swap cases to put your CP3 on the 24 valve. If you have any more questions, feel free to text me at 828-691-5196.
