redjp
- Mar 12, 2006
- Holly Springs
I installed the Rubicon Express standard 3.5 lift on two TJs. now when i hit a bump, at any speed greater than 5mph (even the transition in pavement or crack in the concrete) they start a violent shake that stays until i slow to under 5 mph. Happens at constant speed, accelerating, coasting, clutch in or out no matter what. It seems to be in the driveline since the gearshifter vibrates about 6 inches or so (I said it was violent vibes). One of the Jeeps has a short shaft kit and still does it, but a little less than the other and only when less than 1/2 tank of gas (weight compressing the rear end or something?) neither of them have adjustable control arms (leading me to think i need to check the angles) but there are no vibes really at all if driving on a perfectly flat surface at any speed. I thought I was pinching the yokes, but it is still there with the sye. Have any of you heard of this (I hope it is rather common sicne I am experiencing it with both Jeeps)?
Thanks in advance,
Tony
Thanks in advance,
Tony
