bbbcb04
- Dec 12, 2009
- thomasville
just put a tj grille in my yj and the head lights are pretty dim compared to the yjs. do i need to change any wiring on the plugs. any help would be great
Dim Headlights are almost always a Grounding Issue.I would check to make sure you have good ground from chassis to the grille.You could even try running a ground right over to the battery to test.When you get done with that post pics please,I am always curious to see how that conversion turns out!
