Ray VanBuren
- Jul 26, 2005
- Shelby,NC
Is there any way to remove the dipstick tbe from inside the block without removing the oil pan?
I went to check the oil. As I pulled the dipstick, the tube came off even with the block.seems like you are running into some bad luck
what happened?
AMC 304What type of engine is it? Try a EZout
This on has a mount on the valve cover. But it's not solid.After I broke the second dipstick tube I brazed a bracket to it and bolted it threw a valve cover bolt.
