Disc brake 9" ?
junkman
roxboro
I think I have found a 9" rear with disc brakes under a 76 lincoln towncar. Might swap it into my cj7 instead of the waggy 44.
I would do a search to see if it has the less desirable 28 splines instead of 31? Otherwise a strong unit, there is a reason they use em on the dragstrip!
Sam (my 9" was from 78 Fullsize Bronco)
The car rear will be narrower than a fullsize truck housing. All trucks, except early Broncos, have 31 spline axles. All pass. cars with the exeption of a few rare hipo cars will have the 28's. But if you plan on adding a locker or spool you can change to which ever you wish. The disk brake assy. should swap to any large bearing housing, though.
Weren't the cars a different bolt pattern too?
5 on 5" or something?
