Disengaging beeping when keys in ignition?
vjw0307
Florence
I have a 2003 TJ. Is there away to disengage the beeping noise when your keys are in the ignition? I just want to be able to listen to music while working on the jeep but can't due to the annoying beeping. Thanks for your help in advance guys!
I thought the beeping only lasts a few seconds. Are you using the key in the ON position or accessory position? Maybe its because the door is open, and you just disconnect the button in the door jamb.
Well doors are off and that disconnect has been disengaged. I let the keys stay in for 20 seconds...kept beeping. Put in Aux position, ON position, etc...all continue to beep.
Maybe need to find the wire that tells it the door is open and ground it?
